David32
2 years agoArria 10 HPS EMIF DDR4 failing calibration
Hi, We are using Arria 10 SOC on a custom board. There is a single interface to DDR4 (component, 2 devices, each 16 bits). When doing normal EMIF the calibration succeeds and I can access memory t...
- 2 years ago
Hi Sho,
I am sorry but I forgot to mark this thread as solved.
We found it necessary to mark (within HPS configuration in QSYS) that FPGA boots from SD card.
David
symmt_Intel
2 years agoHi David,
I'm terribly sorry for my late reply.
I'd like to ask you about a few things.
- Could you attach the screenshots of the parameter setting window for both EMIF(non HPS) and HPS EMIF?
- Have you tried changing Quartus version? I'd like you to try other versions to see if the issue will be fixed.
Sho Yamamoto
David32
2 years agoHi Sho,
David
