Arria 10 HPS EMIF DDR4 failing calibration
- 2 years ago
Hi Sho,
I am sorry but I forgot to mark this thread as solved.
We found it necessary to mark (within HPS configuration in QSYS) that FPGA boots from SD card.
David
Hi David,
What do you mean by "doing normal EMIF"?
Did you mean that you referred to GHRD or something, copied the EMIF parameters and pasted them for your own project?
If you use different DDR4 memories, you need different calibration parameters for sure.
Sho Yamamoto
Hi Sho
"Normal" means the instantiation of the (non HPS) EMIF IP within Platform Designer, since an IP also exists for instantiating EMIF to HPS.
These tests were on our custom board, where the "normal" or non-HPS EMIF controller seems to work OK with the DDR4, but the HPS EMIF controller fails on calibration.
David
