gschuell
3 years agoArria 10 HPS EMIF DDR3 Calibration Failure
I am bringing up a custom Arria 10 SX board and have been running into issues with getting my DDR3 SODIMM to calibrate when connected to the HPS EMIF conduit. The EMIF example design calibrates pro...
AdzimZM_Altera
3 years agoHi Greg,
Thank you for providing the pin assignment.
- The pins are placed at HPS EMIF IP.
- Calibration is successful at this pin assignment and with IP timing parameter.
- Can you provide the EMIF IP setting from the Parameter Editor GUI?
- Please provide the memory datasheet as well for checking purpose.
But there is an issue in the U-Boot when using HPS EMIF IP.
- Can you share some snapshots of the errors?
- Is there any timing violation occurred after compiling the design?
- May I know which Quartus version and OS environment that you used?
Thanks!
Adzim
- gschuell3 years ago
Hi Adzim,
I will gather this information and send it as soon as I get a chance.
Greg
