gschuell
3 years agoArria 10 HPS EMIF DDR3 Calibration Failure
I am bringing up a custom Arria 10 SX board and have been running into issues with getting my DDR3 SODIMM to calibrate when connected to the HPS EMIF conduit. The EMIF example design calibrates pro...
AdzimZM_Altera
3 years agoHi!
"The EMIF example design calibrates properly using the same timing parameters as I have in the HPS project."
- Can you share the pin connection of the EMIF interface in the EMIF example design?
"Most of the debug guidelines suggest getting the example design to calibrate successfully and then use those settings for the HPS project, but what other things could cause the calibration failure only on the HPS side?"
- After confirming with FPGA EMIF that the memory and device is working properly, then need to check on U-Boot side.
"Are there any debug interfaces that could be useful in gathering additional calibration status information?"
- Unfortunately we don't have a debug interface to debug the HPS EMIF IP directly.
- To debug the HPS EMIF IP, we instantiated a FPGA EMIF interface at the HPS IO Bank and checked the calibration report from EMIF Debug Toolkit.
Adzim
- gschuell3 years ago
Hello Adzim,
Thank you for your reply.
I've attached the pin connections for the EMIF example design for your review.
Please let me know if this is what you were looking for.
Greg
