AVolo2's avatar
AVolo2
4 years ago
arria-10-gx dev ttack won't install on x86_64
could you advise which exactly OS to install on x86_64 in order for intel dev stack script to work correctly, please? Tried with ubuntu 18,20 with various kernel versions 5.4, 5.8 - it won't work
What OS is supported?
  • AVolo2's avatar
    AVolo2
    lspci -s 07:00.0 -vv
    07:00.0 Processing accelerators: Intel Corporation Device 09c4
    	Subsystem: Intel Corporation Device 0000
    	Physical Slot: 1
    	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
    	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    	Latency: 0, Cache Line Size: 64 bytes
    	Interrupt: pin A routed to IRQ 16
    	NUMA node: 0
    	Region 0: Memory at 80600000 (64-bit, prefetchable) [size=512K]
    	Region 2: Memory at 80680000 (64-bit, prefetchable) [size=512K]
    	Capabilities: <access denied>
    	Kernel driver in use: dfl-pci
    	Kernel modules: dfl_pci
  • AVolo2's avatar
    AVolo2
    it did not work
    ~/a10_gx_pac_ias_1_2_1_pv_dev_installer$ ./setup.sh
     but  it already failed
      add completed.
    Kernel preparation unnecessary for this kernel.  Skipping...
    Building module:
    cleaning build area...
    make -j4 KERNELRELEASE=5.4.0-84-generic KERNELDIR=/lib/modules/5.4.0-84-generic/build.....(bad exit status: 2)
    Error! Bad return status for module build on kernel: 5.4.0-84-generic (x86_64)
    Consult /var/lib/dkms/intel-fpga/2.0.3/build/make.log for more information.
  • AVolo2's avatar
    AVolo2
    I am reinstalling the OS using
    wget https://releases.ubuntu.com/18.04/ubuntu-18.04.6-desktop-amd64.iso
    but it [intel setup script] won't work on fresh installed 18.04 from the iso, will it?
