MehmetFide
4 years agoArria 10 configuration through Linux fpga-arria10-passive-serial driver
We have a products which has iMX8M-Plus processor with an Arria 10 GX FPGA.
We want to configure FPGA each time when our embedded system boots.
To do that we have connected a SoM SPI p...
EBERLAZARE_I_Intel
4 years agoHi,
Can you share your boot logs file here?
MehmetFide
4 years agoHere it is:
root@verdin-imx8mp-06976886:/# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.4.161-rt67-0+git.ea71855f952b (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP PREEMPT_RT Mon Mar 21 19:48:25 UTC 2022 [ 0.000000] Machine model: Toradex Verdin iMX8M Plus WB on GPR Array [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 960 MiB at 0x00000000c0000000 [ 0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030880000 (options '') [ 0.000000] printk: bootconsole [ec_imx6q0] enabled [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000013fffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x13f8413c0-0x13f842fff] [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff] [ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x00000000557fffff] [ 0.000000] node 0: [mem 0x0000000056000000-0x00000000923fffff] [ 0.000000] node 0: [mem 0x00000000a4400000-0x000000013fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff] [ 0.000000] On node 0 totalpages: 972800 [ 0.000000] DMA32 zone: 11104 pages used for memmap [ 0.000000] DMA32 zone: 0 pages reserved [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 [ 0.000000] Normal zone: 4096 pages used for memmap [ 0.000000] Normal zone: 262144 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] percpu: Embedded 20 pages/cpu s44800 r8192 d28928 u81920 [ 0.000000] pcpu-alloc: s44800 r8192 d28928 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 957600 [ 0.000000] Policy zone: Normal [ 0.000000] Kernel command line: root=PARTUUID=941fe322-02 ro rootwait console=ttymxc2,115200 console=tty1 consoleblank=0 earlycon [ 0.000000] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0xbc000000-0xc0000000] (64MB) [ 0.000000] Memory: 2733252K/3891200K available (14012K kernel code, 1030K rwdata, 6204K rodata, 2496K init, 1051K bss, 174908K reserved, 983040K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] No expedited grace period (rcu_normal_after_boot). [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 160 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000 [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] random: get_random_bytes called from start_kernel+0x2bc/0x43c with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns [ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns [ 0.008886] Console: colour dummy device 80x25 [ 0.013392] printk: console [tty1] enabled [ 0.017939] printk: bootconsole [ec_imx6q0] disabled [ 0.023429] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000) [ 0.023433] pid_max: default: 32768 minimum: 301 [ 0.023511] LSM: Security Framework initializing [ 0.023580] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.023597] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.024807] ASID allocator initialised with 32768 entries [ 0.024885] rcu: Hierarchical SRCU implementation. [ 0.026294] EFI services will not be available. [ 0.026478] smp: Bringing up secondary CPUs ... [ 0.026960] Detected VIPT I-cache on CPU1 [ 0.026980] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000 [ 0.027009] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.027590] Detected VIPT I-cache on CPU2 [ 0.027603] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000 [ 0.027621] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.028103] Detected VIPT I-cache on CPU3 [ 0.028116] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000 [ 0.028130] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.028192] smp: Brought up 1 node, 4 CPUs [ 0.028196] SMP: Total of 4 processors activated. [ 0.028199] CPU features: detected: 32-bit EL0 Support [ 0.028203] CPU features: detected: CRC32 instructions [ 0.033709] CPU: All CPU(s) started at EL2 [ 0.033726] alternatives: patching kernel code [ 0.034867] devtmpfs: initialized [ 0.046484] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.046504] futex hash table entries: 1024 (order: 5, 131072 bytes, linear) [ 0.072523] pinctrl core: initialized pinctrl subsystem [ 0.073039] DMI not present or invalid. [ 0.073285] NET: Registered protocol family 16 [ 0.083527] DMA: preallocated 256 KiB pool for atomic allocations [ 0.083553] audit: initializing netlink subsys (disabled) [ 0.083752] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1 [ 0.084432] cpuidle: using governor menu [ 0.085109] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.086177] Serial: AMBA PL011 UART driver [ 0.086235] imx mu driver is registered. [ 0.086258] imx rpmsg driver is registered. [ 0.091790] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver [ 0.113831] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.113839] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.113843] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.113846] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.114757] cryptd: max_cpu_qlen set to 1000 [ 0.117965] ACPI: Interpreter disabled. [ 0.119868] iommu: Default domain type: Translated [ 0.120009] vgaarb: loaded [ 0.120368] SCSI subsystem initialized [ 0.120497] libata version 3.00 loaded. [ 0.120724] usbcore: registered new interface driver usbfs [ 0.120765] usbcore: registered new interface driver hub [ 0.120796] usbcore: registered new device driver usb [ 0.122430] mc: Linux media interface: v0.10 [ 0.122457] videodev: Linux video capture interface: v2.00 [ 0.122531] pps_core: LinuxPPS API ver. 1 registered [ 0.122534] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]> [ 0.122554] PTP clock support registered [ 0.122717] EDAC MC: Ver: 3.0.0 [ 0.123685] No BMan portals available! [ 0.123983] QMan: Allocated lookup table at (____ptrval____), entry count 65537 [ 0.124347] No QMan portals available! [ 0.124894] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree [ 0.125265] FPGA manager framework [ 0.125364] Advanced Linux Sound Architecture Driver Initialized. [ 0.126580] clocksource: Switched to clocksource arch_sys_counter [ 0.126732] VFS: Disk quotas dquot_6.6.0 [ 0.126778] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.126952] pnp: PnP ACPI: disabled [ 0.133705] thermal_sys: Registered thermal governor 'step_wise' [ 0.133709] thermal_sys: Registered thermal governor 'power_allocator' [ 0.134133] NET: Registered protocol family 2 [ 0.134280] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.135655] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.135758] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.136014] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear) [ 0.137380] TCP: Hash tables configured (established 32768 bind 32768) [ 0.137524] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.137800] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.138212] NET: Registered protocol family 1 [ 0.138668] RPC: Registered named UNIX socket transport module. [ 0.138672] RPC: Registered udp transport module. [ 0.138674] RPC: Registered tcp transport module. [ 0.138676] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.138683] PCI: CLS 0 bytes, default 64 [ 0.139413] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.139719] kvm [1]: IPA Size Limit: 40 bits [ 0.140836] kvm [1]: GICv3: no GICV resource entry [ 0.140839] kvm [1]: disabling GICv2 emulation [ 0.140854] kvm [1]: GIC system register CPU interface enabled [ 0.140909] kvm [1]: vgic interrupt IRQ1 [ 0.140990] kvm [1]: Hyp mode initialized successfully [ 0.144171] Initialise system trusted keyrings [ 0.144291] workingset: timestamp_bits=44 max_order=20 bucket_order=0 [ 0.151804] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.152439] NFS: Registering the id_resolver key type [ 0.152458] Key type id_resolver registered [ 0.152461] Key type id_legacy registered [ 0.152472] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.152476] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.152496] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc. [ 0.166191] Key type asymmetric registered [ 0.166196] Asymmetric key parser 'x509' registered [ 0.166225] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.166229] io scheduler mq-deadline registered [ 0.166233] io scheduler kyber registered [ 0.167911] imx8-pcie-phy 32f00000.pcie-phy: failed to get imx pcie phy clock [ 0.170433] EINJ: ACPI disabled. [ 0.176641] i.MX8MP clock driver probe done [ 0.178547] mxs-dma 33000000.dma-apbh: initialized [ 0.179360] Bus freq driver module loaded [ 0.185183] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.187587] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 27, base_baud = 1500000) is a IMX [ 0.187631] printk: console [ttymxc2] enabled [ 0.190218] imx-drm display-subsystem: no available port [ 0.202948] brd: module loaded [ 0.210284] loop: module loaded [ 0.210731] zram: Added device: zram0 [ 0.219427] libphy: Fixed MDIO Bus: probed [ 0.219733] tun: Universal TUN/TAP device driver, 1.6 [ 0.220550] Freescale FM module, FMD API version 21.1.0 [ 0.220803] Freescale FM Ports module [ 0.221150] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found [ 0.221231] imx-dwmac 30bf0000.ethernet: no reset control found [ 0.221912] VFIO - User Level meta-driver version: 0.3 [ 0.225918] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.225926] ehci-pci: EHCI PCI platform driver [ 0.226419] usbcore: registered new interface driver usb-storage [ 0.226494] usbcore: registered new interface driver usbserial_generic [ 0.226510] usbserial: USB Serial support registered for generic [ 0.226536] usbcore: registered new interface driver cp210x [ 0.226554] usbserial: USB Serial support registered for cp210x [ 0.226632] usbcore: registered new interface driver ftdi_sio [ 0.226650] usbserial: USB Serial support registered for FTDI USB Serial Device [ 0.226678] usbcore: registered new interface driver pl2303 [ 0.226700] usbserial: USB Serial support registered for pl2303 [ 0.226726] usbcore: registered new interface driver usb_serial_simple [ 0.226743] usbserial: USB Serial support registered for carelink [ 0.226762] usbserial: USB Serial support registered for zio [ 0.226780] usbserial: USB Serial support registered for funsoft [ 0.226798] usbserial: USB Serial support registered for flashloader [ 0.226819] usbserial: USB Serial support registered for google [ 0.226837] usbserial: USB Serial support registered for libtransistor [ 0.226854] usbserial: USB Serial support registered for vivopay [ 0.226874] usbserial: USB Serial support registered for moto_modem [ 0.226893] usbserial: USB Serial support registered for motorola_tetra [ 0.226911] usbserial: USB Serial support registered for novatel_gps [ 0.226928] usbserial: USB Serial support registered for hp4x [ 0.226947] usbserial: USB Serial support registered for suunto [ 0.226965] usbserial: USB Serial support registered for siemens_mpi [ 0.229407] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0 [ 0.231235] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1 [ 0.231368] i2c /dev entries driver [ 0.240302] imx2-wdt 30280000.watchdog: timeout 60 sec (nowayout=0) [ 0.240658] EDAC MC: ECC not enabled [ 0.241876] sdhci: Secure Digital Host Controller Interface driver [ 0.241881] sdhci: Copyright(c) Pierre Ossman [ 0.242104] Synopsys Designware Multimedia Card Interface Driver [ 0.242804] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.247673] caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9) [ 0.247683] caam 30900000.crypto: job rings = 3, qi = 0 [ 0.255721] caam algorithms registered in /proc/crypto [ 0.256567] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto [ 0.256577] caam 30900000.crypto: registering rng-caam [ 0.256850] Device caam-keygen registered [ 0.259440] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state [ 0.259636] hidraw: raw HID events driver (C) Jiri Kosina [ 0.259754] usbcore: registered new interface driver usbhid [ 0.259757] usbhid: USB HID core driver [ 0.261379] No fsl,qman node [ 0.261383] Freescale USDPAA process driver [ 0.261385] fsl-usdpaa: no region found [ 0.261387] Freescale USDPAA process IRQ driver [ 0.265323] hantrodec 0 : module inserted. Major = 234 [ 0.265910] hantrodec 1 : module inserted. Major = 234 [ 0.266723] hantroenc: HW at base <0000000038320000> with ID <0x80006200> [ 0.266950] hx280enc: module inserted. Major <511> [ 0.274380] pktgen: Packet Generator for packet performance testing. Version: 2.75 [ 0.275317] NET: Registered protocol family 26 [ 0.275896] NET: Registered protocol family 10 [ 0.276500] Segment Routing with IPv6 [ 0.276546] NET: Registered protocol family 17 [ 0.276591] tsn generic netlink module v1 init... [ 0.276645] Key type dns_resolver registered [ 0.277069] registered taskstats version 1 [ 0.277074] Loading compiled-in X.509 certificates [ 0.305270] GPIO line 61 (CTRL_SLEEP_MOCI#) hogged as output/high [ 0.309818] reg-fixed-voltage regulator-module-eth1phy: Failed to register regulator: -517 [ 0.310683] +V3.3_SD: supplied by +V3.3_SW [ 0.312906] pca9450 0-0025: Device ID=0x30 [ 0.313212] pca9450 0-0025: gpio_intr = 3 [ 0.313220] pca9450 0-0025: chip_irq=59 [ 0.318752] random: fast init done [ 0.333549] rtc-ds1307 0-0032: registered as rtc0 [ 0.336520] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write [ 0.336576] i2c i2c-0: IMX I2C adapter registered [ 0.337982] i2c i2c-1: IMX I2C adapter registered [ 0.339694] i2c i2c-2: IMX I2C adapter registered [ 0.341054] i2c i2c-3: IMX I2C adapter registered [ 0.341330] imx8mq-usb-phy 381f0040.usb-phy: 381f0040.usb-phy supply vbus not found, using dummy regulator [ 0.341604] imx8mq-usb-phy 382f0040.usb-phy: 382f0040.usb-phy supply vbus not found, using dummy regulator [ 0.343587] random: crng init done [ 0.343721] imx6q-pcie 33800000.pcie: PLL REF_CLK is used!. [ 0.344332] imx6q-pcie 33800000.pcie: PCIe PHY PLL clock is locked. [ 0.344662] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found [ 0.344739] imx-dwmac 30bf0000.ethernet: no reset control found [ 0.346386] imx6q-pcie 33800000.pcie: PCIe PLL locked after 0 us. [ 0.348042] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 0.348065] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 0.348415] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000002001810010 [ 0.348880] xhci-hcd xhci-hcd.1.auto: irq 52, io mem 0x38200000 [ 0.349944] hub 1-0:1.0: USB hub found [ 0.349971] hub 1-0:1.0: 1 port detected [ 0.350262] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 0.350273] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 0.350285] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 0.350367] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.350872] hub 2-0:1.0: USB hub found [ 0.350895] hub 2-0:1.0: 1 port detected [ 0.351446] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 supported-hw 0x80 0x4 [ 0.391179] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA [ 0.392041] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO [ 0.425805] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA [ 0.446848] mmc0: new ultra high speed SDR104 SDIO card at address 0001 [ 0.455630] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA [ 0.457939] On-module +V3.3_ETH: supplied by On-module +V3.3 (buck4) [ 0.553010] mmc2: new HS400 MMC card at address 0001 [ 0.553730] mmcblk2: mmc2:0001 S0J56X 14.8 GiB [ 0.553875] mmcblk2boot0: mmc2:0001 S0J56X partition 1 31.5 MiB [ 0.554013] mmcblk2boot1: mmc2:0001 S0J56X partition 2 31.5 MiB [ 0.554443] mmcblk2rpmb: mmc2:0001 S0J56X partition 3 4.00 MiB, chardev (236:0) [ 0.555650] mmcblk2: p1 p2 [ 0.558968] imx6q-pcie 33800000.pcie: host bridge /pcie@33800000 ranges: [ 0.558991] imx6q-pcie 33800000.pcie: IO 0x1ff80000..0x1ff8ffff -> 0x00000000 [ 0.559000] imx6q-pcie 33800000.pcie: MEM 0x18000000..0x1fefffff -> 0x18000000 [ 0.606900] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 0.665544] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found [ 0.665611] imx-dwmac 30bf0000.ethernet: no reset control found [ 0.666415] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51 [ 0.666422] imx-dwmac 30bf0000.ethernet: DWMAC4/5 [ 0.666426] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported [ 0.666429] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported [ 0.666432] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported [ 0.666434] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported [ 0.666460] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 0.666465] imx-dwmac 30bf0000.ethernet: Enabled Flow TC (entries=8) [ 0.666473] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256) [ 0.666594] libphy: stmmac: probed [ 0.671801] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 0.672978] rtc-ds1307 0-0032: setting system clock to 2022-03-23T09:21:22 UTC (1648027282) [ 0.690299] ALSA device list: [ 0.690307] No soundcards found. [ 0.799338] hub 1-1:1.0: USB hub found [ 0.799968] hub 1-1:1.0: 3 ports detected [ 0.883232] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd [ 0.927608] hub 2-1:1.0: USB hub found [ 0.928242] hub 2-1:1.0: 2 ports detected [ 1.563927] imx6q-pcie 33800000.pcie: Phy link never came up [ 1.563953] imx6q-pcie 33800000.pcie: failed to initialize host [ 1.563956] imx6q-pcie 33800000.pcie: unable to add pcie port. [ 1.566614] usb 1-1.3: new high-speed USB device number 3 using xhci-hcd [ 1.572334] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.572397] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 1.574218] devtmpfs: mounted [ 1.574958] Freeing unused kernel memory: 2496K [ 1.606951] Run /sbin/init as init process [ 1.706968] systemd[1]: systemd 244.5+ running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 1.707419] systemd[1]: Detected architecture arm64. [ 1.829547] systemd[1]: Set hostname to <verdin-imx8mp-06976886>. [ 2.088024] systemd[1]: Created slice system-getty.slice. [ 2.217724] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 2.339452] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 2.340605] systemd[1]: Created slice User and Session Slice. [ 2.340959] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 2.341245] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 2.341491] systemd[1]: Reached target Paths. [ 2.341623] systemd[1]: Reached target Remote File Systems. [ 2.341742] systemd[1]: Reached target Slices. [ 2.341863] systemd[1]: Reached target Swap. [ 2.342170] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 2.342763] systemd[1]: Listening on Journal Audit Socket. [ 2.343195] systemd[1]: Listening on Journal Socket (/dev/log). [ 2.416339] systemd[1]: Listening on Journal Socket. [ 2.416913] systemd[1]: Listening on Network Service Netlink Socket. [ 2.417318] systemd[1]: Listening on udev Control Socket. [ 2.417622] systemd[1]: Listening on udev Kernel Socket. [ 2.420353] systemd[1]: Mounting Huge Pages File System... [ 2.452180] systemd[1]: Mounting POSIX Message Queue File System... [ 2.456241] systemd[1]: Mounting Kernel Debug File System... [ 2.471815] systemd[1]: Mounting Temporary Directory (/tmp)... [ 2.475715] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 2.493313] systemd[1]: Starting File System Check on Root Device... [ 2.498128] systemd[1]: Starting Journal Service... [ 2.511041] systemd[1]: Condition check resulted in Load Kernel Modules being skipped. [ 2.511346] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 2.514328] systemd[1]: Mounting Kernel Configuration File System... [ 2.517906] systemd[1]: Starting Apply Kernel Variables... [ 2.552457] systemd[1]: Starting udev Coldplug all Devices... [ 2.559365] systemd[1]: Mounted Huge Pages File System. [ 2.567613] systemd[1]: Started Journal Service. [ 2.604115] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null) [ 2.627191] systemd-journald[282]: Received client request to flush runtime journal. [ 3.674882] cdc_acm 1-1.3:1.0: skipping garbage [ 3.692334] cdc_acm 1-1.3:1.1: ttyACM0: USB ACM device [ 3.705826] usbcore: registered new interface driver cdc_acm [ 3.705834] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.849092] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 3.864779] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 3.879797] Bluetooth: Core ver 2.22 [ 3.880001] NET: Registered protocol family 31 [ 3.880005] Bluetooth: HCI device and connection manager initialized [ 3.880018] Bluetooth: HCI socket layer initialized [ 3.880024] Bluetooth: L2CAP socket layer initialized [ 3.880043] Bluetooth: SCO socket layer initialized [ 3.896915] Bluetooth: vendor=0x2df, device=0x9142, class=255, fn=2 [ 3.999807] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5 [ 4.040512] fpga_manager fpga0: altera-ps-spi spi1.0 registered [ 4.040577] spi_imx 30820000.spi: probed [ 4.057585] of-fpga-region altera_region: FPGA Region probed [ 4.388315] using random self ethernet address [ 4.388323] using random host ethernet address [ 4.463527] usb0: HOST MAC 92:59:e8:b2:18:56 [ 4.463607] usb0: MAC 02:46:42:ad:88:d7 [ 4.583500] imx-dwmac 30bf0000.ethernet eth0: PHY [stmmac-0:07] driver [Microchip KSZ9131 Gigabit PHY] [ 4.596578] imx-dwmac 30bf0000.ethernet eth0: No Safety Features support found [ 4.596597] imx-dwmac 30bf0000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported [ 4.596784] imx-dwmac 30bf0000.ethernet eth0: registered PTP clock [ 4.596794] imx-dwmac 30bf0000.ethernet eth0: configuring for phy/rgmii-id link mode [ 4.913810] mwifiex_sdio mmc0:0001:1: info: FW download over, size 623240 bytes [ 5.776145] mwifiex_sdio mmc0:0001:1: WLAN FW is active [ 5.777254] btmrvl_sdio mmc0:0001:2: sdio device tree data not available [ 5.807385] mwifiex_sdio mmc0:0001:1: Unknown api_id: 3 [ 5.807398] mwifiex_sdio mmc0:0001:1: Unknown api_id: 4 [ 5.807402] mwifiex_sdio mmc0:0001:1: Unknown GET_HW_SPEC TLV type: 0x217 [ 5.842282] mwifiex_sdio mmc0:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p197) [ 5.842293] mwifiex_sdio mmc0:0001:1: driver_version = mwifiex 1.0 (16.68.1.p197) [ 5.850104] mwifiex_sdio mmc0:0001:1 wlan0: renamed from mlan0 [ 6.026269] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 31.719604] AUX_USB: disabling [ 31.719616] MIPI_PHY: disabling [ 31.719619] +V1.8_SW: disabling [ 31.719622] +V3.3_SW: disabling [ 31.719625] +V3.3_SD: disabling
