11 years agoArria 10 clock problem
Hello, Im implementing a custom design using Arria 10 (10AX115N4F40I3SG). During Place and Route, the following problem related to clock asiignement appears: :confused: Error (179009): Coul...
11 years ago --- Quote Start --- Hello, Im implementing a custom design using Arria 10 (10AX115N4F40I3SG). During Place and Route, the following problem related to clock asiignement appears: :confused: Error (179009): Could not find enough available I/O pin locations that supports the Current Mode Logic (CML) standard (2 locations affected) Info (175029): AJ5 Info (175029): pin containing PIN_AJ5 The clock im using is mapped to the input PIN_AJ5 of the FPGA on the board. I even checked this PIN in the FPGA pins document and it's a clock input. Does anyone had a similar problem using Arria10? :confused::confused: note: - Im using Quartus v14.1. - This clock is mapped in internal PLL in my design. --- Quote End --- I did a quick check with my Quartus II 15.0 on your device, the pin AJ5 is a normal clock input pin but not transceiver refclk pin. You can try to use other IO standard ie LVDS, LVPECL to see if can pass the compilation.
