LFrin's avatar
LFrin
3 years ago
Arria 10: Booting U-Boot from SD-Card does not configure FPGA
I have adapted the example for the Arria 10 SOCDK (Arria 10 SoC - Boot from SD Card) to the HAN-Pilot-Platform evaluation board from Terasic. I used the make_sdimage_p3.py script to generate the SD-Card image without linux binaries:
Partition 3: (format raw, type 0xA2) - u-boot-splx4.sfp
Partition 1: (format fat) - sdfs folder with - fit_spl_fpga.itb and u-boot.img
Partition 2: (format ext3) - empty
The SOC start-up seems to be ok, but the FPGA does not get configured:
Boot Console Arria 10 SOC
When i start the board without SD-Card, put it in, and then connect with the debugger and start the system with the Debugging U-Boot script. The system boots and the FPGA gets configured…
The start-up runs like from SD-Card, but the FPGA gets configured!
Some more informations:
  1. Quartus (22.3 Pro) compilation with “Early Release of HPS IO”
    1.1 Qsys EMIF with enabled “Early Release Mode”
  2. Convert .sof to .rbf with: quartus_cpf.exe --convert --hps -o bitstream_compression=off golden_top.sof golden_top.rbf
  3. Make fit_fpga_spl.itb with fit_fpga_spl.its in \u-boot-socfpga\board\altera\arria10-socdk
I recompiled U-Boot with #define DEBUG in include\configs\socfpga_common.h and found these error:
No configuration specified, trying default…
Found default configuration: ‘config-1’
FPGA: FPGA node count: 2
FPGA: fpga-periph-1
FPGA: fpga-core-1
FPGA: Start to program core bitstream …
FPGA: Data offset was found.
Can’t get ‘load’ property from FIT 0xffe24ec0, node: offset 248, name fpga-core-1 (FDT_ERR_NOTFOUND)
FPGA: No loadable was found.
FPGA: Using default DDR load address: 0x400 .
FPGA: External data: offset = 0x582d4, size = 0x1dcfb44.
blk_find_device: if_type=6, devnum=0: [email protected], 6, 0
Does anyone have any idea what the problem could be?
  • Hi @aikeu,
    okay, now im sure: The Intel In-System Sources and Probes IP hinders the FPGA from starting normally after it has been correctly configured by SD-Card. Even the old Quartus-Project works without the ISSP-IP. Now it makes sense why the FPGA starts when a connection to the programmer is established via JTAG or similar.
    My workaround will be, that i only use FPGA Firmware without the debugging features (ISSP, SignalTap, ...) on the SD-Card and when i need this debugging features i will start the HPS with the ARMD DS debugger.
    Thanks for the help, my problem has been solved.
    LFrin
  • aikeu's avatar
    aikeu
    Hi LFrin,
    Good that you managed to run a working example on on your side.
    May I know any new findings from your side after you tried to seperate the components build in your project?
    Aik Eu
  • LFrin's avatar
    LFrin
    Hi @aikeu,
    Of course, I can keep you updated. I have successfully put the following components into operation without affecting the SD-Card startup:
    - Of course the Hard Processor System
    - PCI-Express Hard-IP
    - Nios V Soft-IP with I2C/GPIO/Timer/JTAG-Uart/Voltsense/Tempsense
    - Transceiver Native PHY (for SFP+-Fiber-Module)/Reset Controller/ATX PLL
    The only thing missing now is an "In-System Sources and Probes" IP, I think this IP could be the problem.
    Unfortunately I won't get to work on this project this week. But I will get back to you at the beginning of the next week.
    LFrin
  • aikeu's avatar
    aikeu
    Hi LFrin,
    Thanks for your feedback. Looking forward to your new findings.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi LFrin,
    Do feedback to me once you got some update on this week.
    Aik Eu
  • LFrin's avatar
    LFrin
    Hi @aikeu,
    my new Quartus project is now designed like the old one, except that I don't use an "In-System-Source-and-Probes" IP and a "Signal-Tap" instance. In the old project I used the ISSP-IP to reset the FPGA. It might be that the initial value is wrong when booting from SD card and the FPGA stays in reset.
    I believe one of these two instances is causing this problem. Tomorrow I will integrate both into my new project and then see if the error occurs.
    Regards, LFrin
    • LFrin's avatar
      LFrin
      Hi @aikeu,
      LFrin
  • aikeu's avatar
    aikeu
    Hi LFrin,
    Glad that the issue has been resolved and thanks for sharing with the workaround method through your troubleshooting process.
    I will close this thread for now and do consider open a new thread when there is further question.
    Thanks agian.
    Aik Eu
