epissadakis's avatar
epissadakis
1 year ago
Arria 10 boot from MT25QU01G device failure
Hello ,
I have a development board which consists of two arria 10 devices that retrieve the configuration from a MICRON MT25QU01G device .
Although through the usb blaster seems that i can access the memory using JTAG and SFL and successfully write data in the memory , when the two arria devices boot it seems that there is a configuration error.
As referred to the datasheet the first arria is configured in active serial configuration scheme by selecting the appropriate MSEL pins while the other in passive serial .
I have also tied the nCONFIG, nSTATUS , DCLK , (AS_DATA_0 and AS_DATA_1) and CONF DONE as referred in pin connection and guidelines.
Do you know why the FPGAs are not configured properly ?
Manolis
  • Farabi_Altera's avatar
    Farabi_Altera
    Is it possible to separate the A10 to individual configuration ?
    1- First - check if FPGA connections are good by programming via JTAG. Can all the Arria 10 FPGAs able to be programmed via JTAG?
    2- AS mode (does not require microcontroller) - program flash first, at power cycle, the image will automatically uploaded into Arria 10 from flash. Make sure you set MSEL for this Arria 10 to AS mode.
    3- PS mode (required microcontroller to handle configuration) - Make sure you have the design uploaded and programmed into microcontroller prior PS configuration.
    4- Check nSTATUS and CONF_DONE of the AS mode Arria 10. Is it turned high?
    5- Check the nSTATUS and CONF_DONE of the PS mode Arria 10. Is it turned high?
    regards,
    Farabi
    • epissadakis's avatar
      epissadakis
      1. Yes BOTH FPGAs are programmed through JTAG
      2,3. I followed the specification and set the first FPGA in AS mode and the second FPGA in PS mode without any external microcontroller . Is it applicable ?
