14 years agoArrays-VHDL
1.In arrays(of real type ) how are we supposed to find the maximum value index in the array?I think A'HIGH is something different which gives the highest subscript of the array.What's the difference ...
14 years agoMaybe you wan't to do the transition from real to fixed point in matlab.
There should be something (in the fixed point toolbox) named "fixed point objects" Doing that you'll can do the validation of certain fixed point resolutions in matlab. After you've implemented the above in HDL an ecquivalency check against your matlab results is sufficient for verification, which is a huge advantage, because you can have your computer do it for you. Since VHDL2008 there should be fixed point and floating point type packages. The libraries are free for download (google should do the trick). I've no experience with that libraries except that I've successfully compiled an example with QII a long time ago.
