14 years agoarray support
Hi, is there a possibility to define an VHDL array so, that in an EPC3C55 the array uses the internal RAM cells. Actually the array uses only the logic elements. Thanks best Jo
14 years agoThank you Sokrates,
the hint was quiet good. But I have a problem. Let's tell you: I have an external processor interface, where the array is filled with data. In my vhdl module I want to use this data for i.e. an arbitray generator. But when I try to read the data (PhaseTime(15 downto 0) := unsigned(Data(Index+OFS_PHASE_Phasendauer+1)); the syntesis generates only logic modules and no ram. best Jo
