14 years agoarray of ascii
Hello everyone I have a question about the following piece of code IEEE.STD_LOGIC_UNSIGNED.ALL
ARCHITECTURE FSMD OF lcd_driver IS
SUBTYPE ascii IS STD_LOGIC_VECTOR(7 DOWNTO 0);
14 years ago --- Quote Start --- Hello everyone I have a question about the following piece of code
TYPE charArray IS array(1 to 6) OF ascii;
SHARED VARIABLE line1: charArray := (x"31",x"32",x"33",x"34",x"35",x"36");
BEGIN
When i try to change on of the values in line1 array by using: line1(1) := x"20"; i get an error Enybody know what i did wrong ? Thanks in advance --- Quote End --- Shared variables are tricky/risky. You may achieve the same by moving the instantiation of 'line1' as a (normal) variable inside the process where you are using it. If we could see more of your code, we could give better help.
