relsaar
5 years agoAria V Display Port core sometimes disconnected
Hi All
We have a PCB board we designed with AMD 8860 GPU that sends DP video to Aria V Display Port core (Qsys). In some of our boards we sometimes have DP connection issues.
The video signal goe...
Deshi_Intel
5 years agoHi,
FPGA ALM is insides FPGA core logic. Hard periphery IP like transceiver channel count won't matter to it.
So, you want to either
- (A) try out bigger AV FPGA with higher ALM count
- Looking at the excel file is not safe.
- It's better for you to change the example design AV device OPN and test out fitter compilation directly.
- or (B) check to see if you can reduce some feature in DisplayPort IP to reduce the ALM usage in your existing AV FPGA
- I know reducing bit per colour definitely helps
- You can also check to see if "support CTS test automation" setting is enabled in DP IP. Just disable it and regenerate IP again.
dlim
