12 years agoAre Pll outputs in phase between different PLL when using the same reference clock
In the following scenario, If I have PLL A and PLL B driven from the same input reference clock (50MHz). Each PLL creates a 200MHz clock with no phase shift. The PLL is set in 'no compensati...
12 years agoQuartus II will try hard to merge the two PLLs ...
