15 years agoApplication speed enhancement
Hello, We are designing an embedded system used to process video data then send them to another embedded system using Ethernet. Data are sent using NicheStack TCP/IP with MicoC/OS-II. ...
15 years ago --- Quote Start --- how can I find using Wireshark which peer acts as a bottleneck --- Quote End --- As a prerequisite, you have to understand how TCP flow control works, either from the basic RFCs or a TCP/IP networking text book. A scenario, where the receiver throttles transmission speed would be, if ACK is delayed or even retransmission of segments is caused. I agree however with slacker, that you should try UDP for a fast transmission. Here you can immediately detect, if the transmitter is able to keep up with the data rate or possibly the receiver can't manage it.
