15 years agoApplication speed enhancement
Hello, We are designing an embedded system used to process video data then send them to another embedded system using Ethernet. Data are sent using NicheStack TCP/IP with MicoC/OS-II. ...
15 years ago --- Quote Start --- For expectable network throughput with NIOS, you should consult AN 440 accelerating nios ii networking applications. I would also use Wireshark to trace the transmission timing. It can at least show, which peer acts as a bottleneck. --- Quote End --- Hello, Thank you for your reply :). Kindly advise me how can I find using Wireshark which peer acts as a bottleneck. Thanks & Regards
