15 years agoApplication speed enhancement
Hello, We are designing an embedded system used to process video data then send them to another embedded system using Ethernet. Data are sent using NicheStack TCP/IP with MicoC/OS-II. ...
15 years agoIf throughput is desired, I would use UDP and take a look at the following example:
http://alterawiki.com/wiki/nios_ii_udp_offload_example Regards, -- slacker
