Application of SSTL-18 class1 on communication between FPGA&DDR2
Now I am design my development kit , the FPGA I am using is Stratix 2'S device EP2S180F1020C5N , I will use DDR2 soDIMM on my development . So , according to the Handbook , I must use the SSTL-18 class1 or class 2 IO specification on the hardware design . What amazing me is that this specification is just single-end communication specification , that is to say , the signal can transmit from FPGA to DDR2 , if the DDR2 data want to transmit to FPGA , the resistor will not match and may produce a serious reflection . Anyone who knows how to solute this problems please help me , it will be very kind of you!
The SSTL class 2 terminations scheme actually involves termination resistors at the FPGA and the memory side. See Altera AN408 figure 6 for reference. This would be a clear way to avoid the said unsymmetrical termination problem with bidirectional signals. Another option is dynamic OCT at the FPGA side, available since Stratix III.
Unfortunately, you most likely can't place termination resistors at both sides due to layout restrictions. But then, SSTL termination can't be more than a compromise. - Altera_Forum
Wonder if Altera Applicatio Note (AN328) would help you on this ...
http://www.altera.com/technology/memory/devices/stratix2-2gx/mem-stratix2-2gx.html I found below msg in that application notes: On the FPGA side, Altera recommends the Series 25 Ohm without Calibration OCT setting for bi-directional signals (such as DQ and DQS) and the Series 50 Ohm without Calibration OCT setting for unidirectional output signals to the memory (such as DM and address/command). If there are multiple loads on certain FPGA output pins (for example, when the address bus is driven to multiple memory devices on a DIMM), you may prefer to use the maximum drive strength setting over the series OCT setting. Note that when using the OCT feature on the FPGA, the programmable drive strength feature is unavailable. Looks like you need to add series resistors on your signal traces.
