19 years agoAnybody using the temperature diode on Stratix II's?
On my circuit board I brought out the two pins from the temperature diode so that I could measure the temperature with an external device. I have not been able to get decent readings yet--either tha...
19 years agoYes, I have gotten good readings from the temp sense diode. You will see the MAXIM 1619 on some of the Altera evaluation or dev kits along with 7 segment displays. We have not seen problems -- you can use a thermocouple or temp sensing thermal gun to correlate.
