14 years agoanother question
library ieee;
use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity Ttrigger2 is port(t,clk:in std_logic; q:buffer std_logic); end Ttrigger2; architecture b of Ttrigger2 is begin signal qq:std_logic; process(clk) begin if t='1' then qq<=not qq; else qq<=qq; end if; end process; q<=qq; end b; Error (10500): VHDL syntax error at Ttrigger2.vhd(10) near text "signal"; expecting "end", or "(", or an identifier ("signal" is a reserved keyword), or a concurrent statement3 Replies
thank you two.i have a vhdl book.forgive me. tomorrow i have a vhdl exam and i'm anxious .
you really should be fixing syntax problems yourself. Have you got a VHDL tutorial?
Move the line signal qq:std_logic; between architecture and begin.
In addition, you should use a if rising_edge(clk) condition, otherwise that code won't work.
