17 years agoAnother question about component instantiation
I have a query about the component instantiation. The structure of my code is as follows: LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE ieee.std_logic_unsigned.all; entity main is port ( clk : in std_logic; port1: in std_logic; port2: out std_logic; port3: in std_logic; port4: out std_logic ); end main; architecture main_behavior of main is component componet1 is port (clkin : in std_logic; a: in std_logic; b: out std_logic ); end component; component component2 is port ( clkin : in std_logic; c: in std_logic; d: out std_logic ); end component; begin first: abc port map ( clkin =>clk, a=> port1, b=> port2 ); second: def port map ( clkin =>clk, c=> port3, d=> port4 ); end main_behavior; In the code structure above, I have both componet1 and component2 who triggers based on the same clock but they have different input and output ports. However, when I do the simulation, the result is funny: If I have either component1 or component2 only in the code, the simulation is good. but if I use both component1 and compnent2, one component's result is wierd while the other one is good. The weird waveform seems to behave like fighting with itself after some clock cycles periodically. :cool: Can anybody give me some advice on this? THANK YOU SO MUCH FOR YOUR TIME IN ADVANCE!!!!1 Reply
Your top design doesn't contain any logic. It's just wiring the components. Thus it's effectively meaningless for the the timing behaviour. The reported behaviour sounds strange indeed, the reason should be searched either in the component definition or in the particulur simulation setup. If the simulation waveform involves timing violations, the result may depend however on minimal routing delay differences between your simulation designs.
