14 years agoaltsyncram synthesize..
hi, my design contains some parametrized functions memories like altsyncram..when i tried to synthesize my design, the synthesizer treat this function as a black box, and in the post synthesize...
14 years ago --- Quote Start --- ... the synthesizer treat this function as a black box ... --- Quote End --- In the MegaWizard for the RAM component, if you leave the implementation as "AUTO", then the tool will select the RAM. You can however select a specific type of RAM. Even if you instantiate the altsyncram component directly in VHDL or Verilog, you can create a couple of example instances using the MegaWizard to determine the correct values for the generics. Cheers, Dave
