14 years agoaltsyncram in simple dual-port mode
Hi, the altsyncram in simple dual-port mode does not seem to work correctly. It appears to have some internal pipelining on the data and address inputs relative to the wren and even each other. ...
14 years agoThank you, Dave.
Please see my new update which I think contains the information you mentioned. I am also adding the following design file info...and yes, it is AHDL! :-) ...but the megafunction IP is transparent to the HDL, of course. Thanks...here's the relevant code: INCLUDE "altsyncram.inc"; constant TRADE_DAYS_MAX = 60; TradeDays_Store : altsyncram WITH ( ADDRESS_ACLR_B = "NONE", ADDRESS_REG_B = "CLOCK0", CLOCK_ENABLE_INPUT_A = "BYPASS", CLOCK_ENABLE_INPUT_B = "BYPASS", CLOCK_ENABLE_OUTPUT_B = "BYPASS", INTENDED_DEVICE_FAMILY = "Stratix III", LPM_TYPE = "altsyncram", NUMWORDS_A = 2^(log2(TRADE_DAYS_MAX)), NUMWORDS_B = 2^(log2(TRADE_DAYS_MAX)), OPERATION_MODE = "DUAL_PORT", OUTDATA_ACLR_B = "NONE", OUTDATA_REG_B = "UNREGISTERED",--"CLOCK0", POWER_UP_UNINITIALIZED = "FALSE", --RAM_BLOCK_TYPE = "M144K", READ_DURING_WRITE_MODE_MIXED_PORTS = "DONT_CARE", WIDTHAD_A = log2(TRADE_DAYS_MAX), WIDTHAD_B = log2(TRADE_DAYS_MAX), WIDTH_A = 256, WIDTH_B = 256, WIDTH_BYTEENA_A = 1 ); TradeDays_Store.clock0 = clk0; TradeDays_Store.data_a[] = data_stock_data_in[]; TradeDays_Store.address_a[] = TDS_wrAddress[]; TradeDays_Store.wren_a = TDS_wren; TradeDays_Store.address_b[] = TDS_rdAddress[]; data_stock_data_out[] = TradeDays_Store.q_b[];
