11 years agoALTSHIFT_TAPS and timing issue
I am having some problems going from simulation to synthesis in my design. The simulation works fine while the synthesized and fitted design does not. I have written a test bench to synthesize a t...
11 years ago --- Quote Start --- Ah yes. I sse. As long as I keep track of the values at the 8 time slots I can accumulate and subtract the relevant value from the previous set. That makes life easier. Thank you!!!!!! --- Quote End --- If you want easier life then you can use 6 multipliers only (pre add then multiply by a symmetrical coeff)
