11 years agoALTSHIFT_TAPS and timing issue
I am having some problems going from simulation to synthesis in my design. The simulation works fine while the synthesized and fitted design does not. I have written a test bench to synthesize a t...
11 years agoif you have 96 taps for a decimate by 8 filter then you need 96/8 = 12 multipliers only.
If your system clock is faster than data input rate by say 2 then you can opt to use 6 multipliers only.
