14 years agoALTREMOTE_UPGRADE help
Greetings,
I could use some help getting my remote update working. I am using the Megawizard for a Cyclone III fpga and have the following parameters set via an opcode. 1. Write Param is high 2. Param is set to 100 which is read from memory... 3. Data_in is set to the memory location in the EPCS64 I have the second image stored 4. Read source is set to 11. (I'm not sure about this one but this is read from current value) 5. I then am attempting to set the reconfig bit high but am having trouble as all the parameter are only set for a very short amount of time Any ideas how I can better impliment this one? ThanksNo RepliesBe the first to reply
