14 years agoaltremote_update - cold-start issue
Hi, I'm having some problems with the altremote_update core on a Cyclone III FPGA. ===# 1 === - reconfiguration from application offset (0x080000) after cold-start of the system does not...
14 years ago --- Quote Start --- The PLL is not an issue. I use it, too I'm concerned about those 3 minutes With a 25MHz clock and maximum wd timer I calculate you should get about a 21sec timeout. Try with a longer reset cycle time or with a shorter timeout value different from all 1 --- Quote End --- ok, I will try that after the weekend. however I believe that your assumptuon that the ru core is using my clock for operation is wrong. in order to detect errors while loading the new application (crc, timeout) the RU core must be using its own clock independent on the existance of a user one (=valid application image). the 25 mhz should onl be a register interface clock.
