14 years agoaltremote_update - cold-start issue
Hi, I'm having some problems with the altremote_update core on a Cyclone III FPGA. ===# 1 === - reconfiguration from application offset (0x080000) after cold-start of the system does not...
14 years agoThe PLL is not an issue. I use it, too
I'm concerned about those 3 minutes With a 25MHz clock and maximum wd timer I calculate you should get about a 21sec timeout. Try with a longer reset cycle time or with a shorter timeout value different from all 1
