14 years agoaltremote_update - application image mode
Hi, I know there are plenty of threads on this subject, I did read them but I am still confuse. I am using a Cyclone III EP3C10F256C8 FPGA and ECPS16. My intention is to upload the firmwa...
14 years ago --- Quote Start --- If I understand correctly, altremote_update core only preserves the following information across reconfiguration: - cause of reconfiguration - status of 2 previous application configurations (only CIII and Stratix III) - reconfiguration page address (other than CIII and Stratix III) On Cyclone III and Stratix III devices altremote_update core uses a boot address register in order to specify reconfiguration data location and you set it with the 'discard 2 lsb' procedure. All other devices use the page mode and you can only select pages 000 to 111 binary. --- Quote End --- You probably mean CIII and CIV ? (not Stratix III) Also note that using the registers with previous configuration states is a bit confusing. The boot address of the current image is for example read in the Previous State Register 2 (read_source=10b, param=100b)
