14 years agoaltremote_update - application image mode
Hi, I know there are plenty of threads on this subject, I did read them but I am still confuse. I am using a Cyclone III EP3C10F256C8 FPGA and ECPS16. My intention is to upload the firmwa...
14 years agoHi,
thanks for the reply. --- Quote Start --- 1) Param 4 is the boot address (cannot find reference to addr/4 in AN521, see table 4). --- Quote End --- "Address to be written to the ALTREMOTE_UPDATE megafunction is obtained by truncating 2 LSB bits from the word address of the start address. The example below shows truncating 2 LSB bits from 0x70000h which results in 0x1C000h. ". AN521, Figure 5 The altremote_update ug refers to this parameter as page number (0-15)... --- Quote Start --- 3) You may read the altremote_update registers or perhaps use signaltap? --- Quote End --- The problem is that once reconfiguration is started SignalTap cannot be used, because "the instance cannot be found". Does the altremote_update core also get reseted during reconfiguration? Can I read the precedent values once the new firmware(intended or factory) is loaded?
