14 years agoaltremote_update - application image mode
Hi, I know there are plenty of threads on this subject, I did read them but I am still confuse. I am using a Cyclone III EP3C10F256C8 FPGA and ECPS16. My intention is to upload the firmwa...
14 years ago1) Param 4 is the boot address (cannot find reference to addr/4 in AN521, see table 4).
2) The image will be bootable if moved from 0x0000 to your new boot address. Unless you have a Nios processor with software for the image. In that case you would have to modify the nios bootloader. (Its just changing an address) 3) You may read the altremote_update registers or perhaps use signaltap? Note that reading the registers of altremote_update for Cyclone III and IV is a bit confusing. The parameters are available at different read_source settings. See table 4 of AN521.
