15 years agoALTPLL constant output
Hi, I'm using a ATLPLL IP In my design. The PLL has one input clock, one areset, one Lock output and one output clock. The input clock is 50MHz . The PLL outputs should be 100MHz. I want the o...
15 years agoNot in general.
Maybe that, if your frequency drift is fast enough and with a zero average value, the bandwidth of the PLL can filter it out. Altera PLL have a programmable bandwidth that you can set to LOW to increase the rejection to input frequency changes. This will affect your lock time however. For a manual: http://www.altera.com/literature/ug/ug_altpll.pdf
