kikoss
2 years agoALTLVDS TX IP - pin location constraints
Hello I Instantiated on my design an ALTLVDS TX module for agilex7 , and the compilation passed This ALTLVDS TX module output 4 differential ports (configured to 192Mbps each one ) + 1 diffe...
- 2 years ago
did you assign LVDS IO standard? Did you try to assign explicite pin locations for differential pairs? You only need to assign positive pins, negative pin will be assigned by fitter automatically.
kikoss
2 years agoHello Yes, I accept it as solution ...
THX
