9 years agoALTLVDS_RX->LVDS serdes Link Training
Implementing Receiver interface. From transmitter we have 8 LVDS data channel and 1 LVDS sync channel. From sync channel we use to get training pattern which will be available in data channel for lin...
9 years ago --- Quote Start --- If you can close static timing then bit alignment is not needed - it's already done. If you can do that at 576Mbps you're a better engineer than I am! --- Quote End --- It rather depends on the transmitting device. Unfortunately the OP didn't tell us what device it is. I have closed 600 Mbps in Cyclone II, the source devices were TI octal ADCs using a home-made deserialiser. Here is an image of the board with 16 ADCs:http://c-cam.be/images/img_7.jpg (http://c-cam.be/images/img_7.jpg)
