14 years agoALTLVDS Megafunction Quartus11.0 doesn't support
Hi all.
I use Quartus 11.1 SP2 to Develop Stratix IV . The Stratix IV need receive image data via LVDS interface . I use Mega-Wizard to generate the ALT_LVDSRX Megafunction IP with Quartus 11.1. It is failed .is there anyone encounter this problem?2 Replies
Runs ok under version 10.1 (no SP) in 32 bit mode. Doesn't work in 64 bit mode due to CNX file error
I'm trying with 11.1 SP2 under Linux (32 bit). I can't get the LVDSRX to run either. It starts running Java and shows about 1/3 of a progress bar and then reports a segmentation fault on the console.
Seems to be a (rather simple) problem that Altera can't solve with many Megafunction plugins.
