11 years agoALTIOBUF dynamic delay, MEMORY_INTERFACE_DATA_PIN_GROUP, pin sans memory interface
Hi, I am using the dynamic delay, operationally modified IO pin delay, feature of ALTIOBUF and the documentation indicates that I must set the MEMORY_INTERFACE_DATA_PIN_GROUP assignment. This w...
11 years agoResponse from Altera Technical Support:
For your information, the dynamic delay chains are only available on I/O pins where the special function is labeled as “DQ/DQS”. There is a solution published as below: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04212011_682.html
