19 years ago
altera SOPC global user libraries
I am a newbie in this altera stuff and have got DE2 board to work on. I tried to run tutorial "tut_sopc_introduction" but have got into problems. I hope the expert advices from you guys will help me out.
Main problem is that whenever I try to do system generation on SOPC, I get this error that:
one or more components could not be located (altera_nios2):... I added to the global user libraries the path "D:\altera\kits\nios2_60\components\altera_nios2".and regenerate but to no avail. I tried with "D:\altera\kits\nios2_60" or "D:\altera\kits\nios2_60\bin". None worked.
My Quartus_v7.1 is on the c:\altera but Nios_v2.0 is on d:\altera...Is this the problem? I am not sure. I hope for your help.
    I got it to work..I used Quartus Version5.1... I dont know why it doesnt work for v7.1...
    --- Quote Start ---
    (...) one or more components could not be located (altera_nios2) (...)
    --- Quote End ---
    If you haven't done so, please install the IP Megacore Library 7.1 and the ServicePack 1.
    Hi there, you should add the 'components' folder to SOPC Builder search path. In your case, add "D:\altera\kits\nios2_60\components".
    SOPC Builder searches all the folders underneath for 'class.ptf' files automatically.
    In Quartus II v7.1 you might have to delete the SOPC Builder cache (in Windows: \Documents and Settings\<profilename>\.altera.quartus) and restart SOPC Builder.
