17 years agoAltera PLL simulation with Modelsim
Hi All,
I am currently simulating a design which internally uses a ALTPLL in one of its internal modules. When I try to simulate in Modelsim I get the following error message when I do the run command: # ** Fatal: (SIGFPE) Floating point exception. And comes as a Fatal Error in altera_mf.vhd (which is autogenerated by Altera). I tried setting my resolution to different values , still I am seeing the same error. Currently my resolution is set to 'ps'.Any help will be much appreciated. Thanks Binu4 Replies
I guess, -t ps has the same effect as this setting in modelsim.ini?
Resolution = ps - Altera_Forum
I just fixed my problem by adding -t 1ps:
vsim -vopt work.pll52_3s_vhd_tst -t 1ps I was getting the same error without that. - Altera_Forum
I have have the same problem. Any solution? Thanks - Altera_Forum
Hi Binupr,
Did you find a solution to this issue? I am having a similar issue and would be interested to know how you finally got around it. Many thanks, Ardni
