9 years ago
Altera On-Chip Flash IP Core
I've included Altera On-Chip Flash IP Core in my project. The core created a component
component flash_update is
        port (
            clock                   : in  std_logic                     := 'X';             -- clk
            avmm_csr_addr           : in  std_logic                     := 'X';             -- address
            avmm_csr_read           : in  std_logic                     := 'X';             -- read
            avmm_csr_writedata      : in  std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
            avmm_csr_write          : in  std_logic                     := 'X';             -- write
            avmm_csr_readdata       : out std_logic_vector(31 downto 0);                    -- readdata
            avmm_data_addr          : in  std_logic_vector(18 downto 0) := (others => 'X'); -- address
            avmm_data_read          : in  std_logic                     := 'X';             -- read
            avmm_data_writedata     : in  std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
            avmm_data_write         : in  std_logic                     := 'X';             -- write
            avmm_data_readdata      : out std_logic_vector(31 downto 0);                    -- readdata
            avmm_data_waitrequest   : out std_logic;                                        -- waitrequest
            avmm_data_readdatavalid : out std_logic;                                        -- readdatavalid
            avmm_data_burstcount    : in  std_logic_vector(3 downto 0)  := (others => 'X'); -- burstcount
            reset_n                 : in  std_logic                     := 'X'              -- reset_n
    end component flash_update;
    u0 : component flash_update
        port map (
            clock                   => CONNECTED_TO_clock,                   --    clk.clk
            avmm_csr_addr           => CONNECTED_TO_avmm_csr_addr,           --    csr.address
            avmm_csr_read           => CONNECTED_TO_avmm_csr_read,           --       .read
            avmm_csr_writedata      => CONNECTED_TO_avmm_csr_writedata,      --       .writedata
            avmm_csr_write          => CONNECTED_TO_avmm_csr_write,          --       .write
            avmm_csr_readdata       => CONNECTED_TO_avmm_csr_readdata,       --       .readdata
            avmm_data_addr          => CONNECTED_TO_avmm_data_addr,          --   data.address
            avmm_data_read          => CONNECTED_TO_avmm_data_read,          --       .read
            avmm_data_writedata     => CONNECTED_TO_avmm_data_writedata,     --       .writedata
            avmm_data_write         => CONNECTED_TO_avmm_data_write,         --       .write
            avmm_data_readdata      => CONNECTED_TO_avmm_data_readdata,      --       .readdata
            avmm_data_waitrequest   => CONNECTED_TO_avmm_data_waitrequest,   --       .waitrequest
            avmm_data_readdatavalid => CONNECTED_TO_avmm_data_readdatavalid, --       .readdatavalid
            avmm_data_burstcount    => CONNECTED_TO_avmm_data_burstcount,    --       .burstcount
            reset_n                 => CONNECTED_TO_reset_n                  -- nreset.reset_n
How should I use it to program CFM on MAX10? I need some example.
    Well...To compile successfully the Qsys and the project should be configured as Single Compressed Imaged. I don't know how it would impact the project. Have to try.
    I included in my project Flash IP. Compiled and opened qip file. The file imported in my project some files.
    flash/flash/synthesis/flash_update.qip
          flash/flash/synthesis/flash_update.vhd
          flash/flash/synthesis/submodules/altera_onchip_flash_util.v
          flash/flash/synthesis/submodules/altera_onchip_flash.v
          flash/flash/synthesis/submodules/altera_onchip_flash_avmm_data_controller.v
          flash/flash/synthesis/submodules/altera_onchip_flash_avmm_csr_controller.v
          flash/flash/synthesis/submodules/altera_onchip_flash.sdc
          flash/flash/synthesis/submodules/rtl/altera_onchip_flash_block.v
    I created my file and included a component from flash_update.vhd. Everything compiles OK. But when I include my component in the top entity I get the following error
    Error (14740): Configuration mode on atom "bootloader:U_BOOTLOADER|flash_update:U_FLASH_UPDATE|altera_onchip_flash:onchip_flash_0|altera_onchip_flash_block:altera_onchip_flash_block|ufm_block" does not match the project setting. Update and regenerate the Qsys system to match the project setting.
