10 years ago
Altera Modelsim vsim-3601
Hi everyone!
When i start simulation in quartus the following error message appear:
"(vsim-3601) Iteration limit 5000 reached at time 0 ps"
My testbench is:
`timescale 1 ns/ 1 nsmodule buffer_vlg_tst();
reg CLK_50MHz;
wire   data_out;
buffer i1 (
          .CLK_50MHz(CLK_50MHz),
          .data_out(data_out)
initial
begin
    CLK_50MHz=1'b1;
    $display("Running testbench");
     forever# 20 CLK_50MHz= ~CLK_50MHz;
end
Any thoughts would be very helpful. Thanks!
    --- Quote Start ---
    You have a forever statement inside the initial block. The initial block is for things that happen at time 0. You can't have something go on forever at time 0.
    --- Quote End ---
    In a testbench, initial blocks can be used to drive stimulus during simulation for example - a reset:
    initial begin
            rst = 1;
            repeat(5) @ (posedge clk) ;
            rst = 0;
        end
    But the OP has generated the clock incorrectly. By using# 5 on the assignment, you only delay the assignment, not the loop, causing the 5000 iteration limit as it is trying to assign the clock at time zero. To do it correctly in an inital block:
    inital begin
      forever begin
       # 20;
      end
    end
    Tricky, the code is:
    macromodule buffer (
    					input CLK_50MHz,
    					output  data_out
    wire  data_count;
    counter count (
    					.clock(CLK_2KHz),
    					.q(data_count));
    pll my_pll 		(
    					.inclk0(CLK_50MHz),
    					.c0(CLK_2KHz),
    					.c1(CLK_8KHz));
    serializer serial (
    					.clk(CLK_8KHz), /*start,*/
    					.inp_data(data_count),
    					.out_data(data_out),
    					.capture(CLK_2KHz));
    endmodule
    module serializer(clk, inp_data, out_data, capture);
    input clk, capture;
    input   inp_data;
    output  out_data;
    reg  counter;
    reg  out_data;
    reg  temp_data;
    always @(posedge capture) temp_data <= inp_data;//input data bufferization
    always @(posedge clk)
    begin
    	counter <= 2;
    	counter <= counter + 1'b1;
    end
    begin
    	case(counter)
    		2'd0: out_data <= temp_data;	//2
    		2'd1: out_data <= temp_data;	//1
    		2'd2: out_data <= temp_data;	        //4
    		2'd3: out_data <= temp_data;	//3
    	endcase
    end
    endmodule
    --- Quote Start ---
    whats the code inside the buffer module?
    --- Quote End ---
    The code is:
    					input CLK_50MHz,
    					output  data_out
    wire  data_count;
    counter count (
    					.clock(CLK_2KHz),
    					.q(data_count));
    pll my_pll 		(
    					.inclk0(CLK_50MHz),
    					.c0(CLK_2KHz),
    					.c1(CLK_8KHz));
    serializer serial (
    endmodule
    input clk, capture;
    input   inp_data;
    output  out_data;
    reg  counter;
    reg  out_data;
    reg  temp_data;
    begin
    	counter <= 2;
    end
    begin
    	case(counter)
    	endcase
    end
    endmodule
