10 years agoAltera Modelsim vsim-3601
Hi everyone! When i start simulation in quartus the following error message appear: "(vsim-3601) Iteration limit 5000 reached at time 0 ps" My testbench is:
`timescale 1 ns/ 1 nsmod...
10 years ago --- Quote Start --- whats the code inside the buffer module? --- Quote End --- The code is:
macromodule buffer (
input CLK_50MHz,
output data_out
wire data_count;
counter count (
.clock(CLK_2KHz),
.q(data_count));
pll my_pll (
.inclk0(CLK_50MHz),
.c0(CLK_2KHz),
.c1(CLK_8KHz));
serializer serial (
.clk(CLK_8KHz), /*start,*/
.inp_data(data_count),
.out_data(data_out),
.capture(CLK_2KHz));
endmodule
module serializer(clk, inp_data, out_data, capture);
input clk, capture;
input inp_data;
output out_data;
reg counter;
reg out_data;
reg temp_data;
always @(posedge capture) temp_data <= inp_data;//input data bufferization
always @(posedge clk)
begin
counter <= 2;
counter <= counter + 1'b1;
end
begin
case(counter)
2'd0: out_data <= temp_data; //2
2'd1: out_data <= temp_data; //1
2'd2: out_data <= temp_data; //4
2'd3: out_data <= temp_data; //3
endcase
end
endmodule
