10 years agoAltera MAX10 I/O pin performance confusion
I am designing Altera max10 motor control board that will use 1MHz PWM as well as >100MHz LVDS comunication with controller. I need lot of CMOS (2.5-3.3V) pins capable more than 1-10MHz ( just for safety and peace of mind) i was unable to find any data on this High speed and low speed GPIO, how they are different ? ( Ok, high speed banks usually have true lvds drivers ( bottom bank) ) But how about single ended performance, how they are different, what is the jitter performance, and maximum safe frequency ? On cyclone i should not use VREF pins as high speed io, i get that, but for normal low speed IO with no dedicated function for VREF and programming ? So questiuon is, what is the difference ? Quote from pins description guide Low speed: "These are I/O pins. Low_Speed I/O pins have lower performance compared to High_Speed I/O pins. Low_Speed I/O pins reside in Banks 1A.." High Speed: "These are I/O pins. High_Speed I/O pins have higher performance compared to Low_Speed I/O pins. High_Speed I/O pins reside in Banks 2, 3, 4, 5, 6, and 7."1 Reply
10 MHz is a low frequency for an FPGA. Every pin should be capable of that frequency.
