10 years agoAltera Max II Cpld (EPM240T100C5N) and internal oscillator. How to use it?
Hi, I'm trying to use the Max II Cpld in a project and I'm trying to find a simple solution to my case. Well, seems that the Max II has an internal oscillator, so can I use it instead of an external clock?
The Max II has 4 pins for external clock, but if it has an internal clock I want to use it instead of worrying about this extra stuff. Someone can please give me some information about this? What is the speed of this internal oscillator? What I need to do to use it? The result will be the same as using an external clock? Thanks....1 Reply
--- Quote Start --- Someone can please give me some information about this? What is the speed of this internal oscillator? What I need to do to use it? The result will be the same as using an external clock? --- Quote End --- Here's example code to simulate and synthesize the internal oscillator. Read the comments in the files for details. For example, src/toggle.vhd
Cheers. Dave-- -- MAX II CPLDs have a User Flash Memory (UFM) block that -- includes an oscillator. The nominal frequency of the -- oscillator is around 18MHz. A divided-by-4 version of the -- oscillator is available to clock user logic. -- Reference indicates that the nominal frequency of the -- user clock signal is 4.4MHz, with a range of 3.3MHz to -- 5.5MHz (25% variation). --
