14 years agoAltera Flex10K, EPF10K10LC84 dev board
hi i have got an Altera Flex10K, EPF10K10LC84 dev board, which has byteblaster programmer onboard, unfortunately my PC has no LPT port in order to connect the byteblaster so i ordered usb blaster ...
14 years ago --- Quote Start --- the problem is: i am on x86 laptop which has no lpt port, modern laptops and desktops do no have lpt port, too. --- Quote End --- What I am suggesting is: 1) Plug you USB-Blaster into your laptop. 2) Connect the 10-pin header on your USB-Blaster to the appropriate JTAG pins on the ByteBlaster DB25 connector. The signals you need to connect are TCK, TMS, TDI, TDO, GND, and VCC to power the buffer in the JTAG cable. Then you can use the USB-Blaster to control the board. Cheers, Dave
