14 years agoAltera Flex10K, EPF10K10LC84 dev board
hi i have got an Altera Flex10K, EPF10K10LC84 dev board, which has byteblaster programmer onboard, unfortunately my PC has no LPT port in order to connect the byteblaster so i ordered usb blaster ...
14 years ago --- Quote Start --- I think the Altera UP1/UP2/UP3 boards have a connection like this, so you can daisy chain boards. However, they have two JTAG connectors, one for the USB-Blaster (or ByteBlaster at the time they were created) and then another for the daisy chain. Does your board have two JTAG connectors? --- Quote End --- Unfortunately no, the byteblaster is onboard and the jtag connector is for the last device on the jtag chain, it is not for the usbblaster cable, i mean if you plug the usb-jtag-cable there you will be wrong in the jtag chain --- Quote Start --- I'd create a USB-Blaster to ByteBlaster cable adapter. It won't take very long. Get a DB25 connector and a 10-pin header, and wire them up. --- Quote End --- the problem is: i am on x86 laptop which has no lpt port, modern laptops and desktops do no have lpt port, too. An other problem is all usb-to-parallel port adapter are not working, so the only solution is to use the usb-jtag. this is the connection scheme i got reversing the board
parallel port
| byteblaster |
| jtag |
tdi tdo tms tck
| | tdi | |
| | eeprom |----+ |
| | epc2lc20 |---------+
| | tdo | |
| | tdi | |
| | flex10k |----+ |
| | epf10k10lc84 |---------+
| | tdo | |
| | tdi | |
| | j2 connector |----+ |
| | to other |---------+
| | jtag chain | | |
| | tdo | |
