14 years agoAltera Flex10K, EPF10K10LC84 dev board
hi i have got an Altera Flex10K, EPF10K10LC84 dev board, which has byteblaster programmer onboard, unfortunately my PC has no LPT port in order to connect the byteblaster so i ordered usb blaster ...
14 years ago --- Quote Start --- My problem is that the flex10K board has a jtag port but i can't recognize the device if i put my usb blaster cable on it. --- Quote End --- What version of Quartus are you using? If you want to synthesize for the FLEX10K devices, you need to install 9.0SP2. I think the latest version of Quartus should still recognize a FLEX10K device, even if it will not let you synthesize a design for it. Have you tried using the JTAG debugger to read the IDCODE? How have you wired your USB-Blaster into the FLEX10K board? You comment that the board has a byte-blaster circuit built into it. Did you connect your USB-Blaster to the inputs to this byte-blaster circuit, or did you remove it, and attach the USB-Blaster directly to the FPGA JTAG pins? The USB-Blaster power for its internal buffer comes from the target, so you need to make sure you have that connected. Cheers, Dave
