12 years agoAltera EPM-7128SQI100-10 Latch-up/Failure
Hi all, We are using this chip on our CPU control board (EPM-7128SQI100-10) this is installed in a High Power Amplifier that has high voltages in it (~18-19KVDC). We've recently started se...
12 years agoI suspect you're assessment has merit. How far away from the HPA can you route the ribbon cable?
Whatever the answer, you need a safe way off assessing the advantage of moving the cable. Assuming you're keen not to blow more of these devices up I suggest you work with a board with the device removed. You then need to assess why: --- Quote Start --- the HV arcs to the chassis for some reason --- Quote End --- so you can do your best to reproduce it and observe what, if anything, is induced on to the ribbon cable. Regards, Alex
