12 years agoaltera epf6016 5 Volt connection schematic
Hi to all, i were looking for a 5volt fpga device and i've found that ALTERA FLEX 6000 could be the right choice. In order to configure and program this device it's necessary to connect the fpga...
12 years agoFLEX 6000 may well be a suitable device. Have you found anyone actually selling them? That is a very old device family...
If you need 5V compatible I/O then I'd suggest you do this level translation outside of the FPGA. This would allow you to use a much newer device (that will be available and much, much cheaper). You could configure the FPGA with a serial configuration device, similar to the EPC1441. However, again, I'd suggest a newer, cheaper and more widely available device (such as an EPCS equivalent). Regards, Alex
