rshal2
7 years agoAltera emac: Is it TSE or designware?
Hello, I am a bit confused with altera emac. I need to use emac from HPS in arria V or cyclone V. Checking both TRM documentation of these FPGA, it is described (in each TRM , and also in memory m...
Deshi_Intel
7 years agoHI Ranran,
If you refer to the reference design that I shared with you in another Forum post
https://rocketboards.org/foswiki/Projects/AlteraSoCTripleSpeedEthernetDesignExample
Looks like HPS ARM processor is able to connect to FPGA core then to TSE IP.
However, it's best if you open up the reference design in Quartus and double check on it.
dlim
- rshal27 years ago
Hello Dlim,
I hope I can ask one more on this. I haven't yet checked the reference example, I feel like I still miss some background understanding on the subject.
What do you mean by "Looks like HPS ARM processor is able to connect to FPGA core then to TSE IP. " ?
What is the difference between HPS access to FPGA and HPS ARM access TSE IP ?
Is it that the first case means that TSE is already memory mapped to arm, while the second requires a bridge to HPS ?
Another thing, in arria v reference documentation (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-v/av_54012.pdf) I don't see any mention on TSE is the memory address map, so where can I find how to access TSE from ARM in documentation ?
Thanks!
ranran
