rshal2
7 years agoAltera emac: Is it TSE or designware?
Hello, I am a bit confused with altera emac. I need to use emac from HPS in arria V or cyclone V. Checking both TRM documentation of these FPGA, it is described (in each TRM , and also in memory m...
Deshi_Intel
7 years agoHi Ran,
Arria V or Cyclone V SOC FPGA support 2 different type of EMAC IP.
1) HPS -> Design Ware EMAC IP
2) FPGA core logic -> soft TSE MAC IP
If you are interested with using HPS to interact with EMAC, then you should go with DesignWare EMAC.
dlim
rshal2
7 years agoHello Dlim,
Thanks you very much.
But is it possible to use FPGA core TSE MAC and still get the EMAC output from the HPS pins ?
ran
